We've got concealed toilets plumbed in to our bathrooms - and although I can understand that it improves the look, it's much harder to fix problems (as invariably there is inadequate access!).
I noticed that we've started to get a dribble of water into the pan, which causes the fill valve to constantly try and keep the water topped up. I did a google, expecting to replace the full flush valve component - but I thought I'd pull it out first and have a look:
It turns out that the seal/washer between the flush valve and cistern base has blistered. I took a photo so that you can see the little bubbles. These were only visible on the underside of the washer, so it may not be apparent unless you take it off the valve completely:
Anyway, if you have a concealed Geberit cistern and have a slow leak into the pan, try checking this seal for blisters and then buy a replacement for a couple of quid - it's much cheaper than replacing the whole flush valve! I bought one from Amazon and it was a genuine Geberit part, but this time made of a transparent silicone, which I hope it more resilient.
