Any advice please for a Frigidaire free standing cooker - the hob plates heat up fine, but neither the large nor small(grill) ovens work. The control panel lights up ok. Is this a fuse problem? Or heating element?
Check the voltage across the element terminals for 240 volts which I doubt you have. You also need to check the oven heating element and the temperature sensor.
