- Joined
- Jun 12, 2020
- Messages
- 2
- Reaction score
- 0
- Country
I have an anglepoise lamp with a fluorescent bulb. The 3 pin plug (marked Power Supply BL1/240 for PL Lamps) has disintegrated. Can I replace it?
Hi and welcome.I have an anglepoise lamp with a fluorescent bulb. The 3 pin plug (marked Power Supply BL1/240 for PL Lamps) has disintegrated. Can I replace it?
If you can't find the rating information on the broken plug, what does it say on the fluorescent bulb?It is a plug adapter that goes straight into the mains with no connectors in between but I have no idea where to get one. I have looked online but can’t find anything similar - only plugs that look nothing like it & take a separate lead.
But if it is a plug/adapter, (like you get with many led fairy lights) you need to get a replacement with the same values. It should tell you on the bottom of the lamp or on the plu/adapter, what it's rated at.
I had a similar problem once - physical damage to the wall-wart ballast for a desk light like that.I have an anglepoise lamp with a fluorescent bulb. The 3 pin plug (marked Power Supply BL1/240 for PL Lamps) has disintegrated. Can I replace it?
