Hi there,
I’m building a bootroom, something quite similar to this.
I have put up the shelf, and also the plywood which is flat on the wall beneath it, which the coat hooks will go onto. The wall is dot and dab, so my shelf and the plywood are securely fixed in using corefix dot and dab fixings.
I have very cleverly not thought about how I’m going to fix the coat hooks onto the surface of the ply until now. The ply is 12mm thick so essentially any fixing will be going through that and into plasterboard.
Any hole that I drill through the ply to get a plug into the plasterboard is going to be too wide as a pilot hole in the ply.
Am I just going to have to get as big a thread of wood screw as possible and hope that that will hold onto the 12mm of ply firmly enough?
Any advice appreciated - thanks
