Hi. I'm sure you would've encountered this situation before, a product places exorbitant amount of forces on plastic tabs and they eventually fail. This happened to me. The product is an aftermarket rear view mirror. To fix it to the mirror, there are 2 spring loaded clamps. The springs are strong but I didn't know they were held by tiny plastic tabs until I opened it up. I had to do that because one of them broke.
Here's how the good side looks like:
And here's the broken side:
Here's a picture of the broken tab:
My question is can this be repaired? If so, what would you use to fix it? In the past I've tried CA glue but it doesn't hold enough force. In the installed position, the spring is always in a pulled state.
I don't know what kind of plastic this is but it would be the most common cheap plastic out there.
