I'm trying to install an ecobee 4 thermostat, I have a dual transformer HVAC system, the HoneyWell Oil burner has internal voltage (approx 24VAC) and a Fan Control Center (that can be regarded as an external 24VAC adapter) I put together a diagram using draw dot io ,
Then someone on a DIY forum helped correcting it ,
I needed a second opinion do these look right? and don't smart thermostats have an internal jumping mechanism when needed between Rc and Rh? would that red jumper in the corrected diagram still be needed? thanks in advance
