I need to run some cable between two rooms at slightly different levels in a terrace house loft conversion. I know that there is insulation board between the walls as it was only built a few years ago.
Is it better to find a timber stud and drill through that from one room to the next or go through the insulation? I ask as I'm not sure if going through the board will lead to a lot of mess or damage or if there is a risk I'm unaware of.
The cable won't be running outside, the hole will be between internal wall to internal wall.
Thanks.
Thanks.
