- Joined
- Aug 19, 2019
- Messages
- 103
- Reaction score
- 14
- Country
Hi
not sure if this a window issue but I am in this house for the first winter and I am getting black mould around the window frame where it meets the wall. The walls of the house are solid stone around 2ft thick. The house is in 2 sections and the more modern section with cavity walls is not showing any damp. I believe all the windows in the property were replaced at the same time. I am wondering if the fitting company did not fit the windows in the old part of the house correctly. I do have a problem with water ingress above one of the other windows (window cladding leak picture) but it is hard to tell exactly where it is coming through due to wooden cladding in the window casement. It also looks like a DPM has been installed under the planks above the window but it doesn't appear to have worked as water drips through around the middle plank when it rains
I am unsure if this is a window or penetrating damp issue or cowboy window fitters
