I am currently working on a project which requires the use of a hole saw to cut 83mm and 104 mm dia. holes in galvanised corrugated roofing sheet.
I have managed to cut a few 83mm holes but it was hard work as the only hole saw of the correct diameter I can find has a 5 teeth per inch pitch which, when cutting metal of 0.55mm, causes a great deal of snagging. Eventually resulting in three teeth being knocked off the blade.
Any advice would be gratefully accepted.
