Where the wall meets the window there is a plastic trim. I took it off because there is a damp patch under the window sill in the corner. I was trying to find the answer to the damp and so took the plastic trim off. It's about an inch thick. This brought off some of the skimmer plaster but behind it there is plaster/Mortor that is cracked but stuck there wobbling... What is the best way to repair it. For the gap I was gunna foam it but I cant just leave broken bits of plaster/Mortor holding on. Can you help me please.... It has been causing me alot of stress
