Crack on fibreglass bath edge
hi there
i had to remove the side panel on a bath recently and while pulling off the tiles i cracked the corner of the bath, i managed to glue the peice back on and it does not look to bad however you can still see the crack.
so the question is there anything that you can be used to conseal the crack
Ivan
I believe you would have to get some of the same colored gelcoat from the manufacturer and proceed as you would with a fiberglass boat or car body.
Hi there Doug thanks for the reply i did think that might be the way Ivan
