I have a 1918 rowhouse and am running into some trouble with a couple 3 way switches. I have a porch light that is controlled by a 3 way switch outside on the porch and another 3 way switch inside the front door. We'd like to convert the outside switch to a GFI and control the porch light using the interior switch.
The interior outlet contains a black, a white, and a red wire that are connected to the 3 way switch. There are also two additional white wires that are tied to each other but not attached to the switch. The outside outlet contains a black, a white, and a red wire.
We were able to get the GFI outlet operable but hooking it up to the live and the neutral and leaving the red off. We tried just about every combination in the interior outlet to get the switch to operate the light but have been unsuccesful. Does anyone have any guidance?
Thanks in advance.
Thanks in advance.
