Hi all, I’m replacing this old bathroom vent (currently vents into attic) with a new larger Panasonic fan with a sufficient CFM rating for the master bathroom & will add a 6” insulated duct to vent it out of the roof.
The current fan is 11” both sides whereas the new fan will need 11” on one side but at least 20” on the other side (to accommodate the 6” duct being fixed to the fan’s air outlet.
I think the only way the new fan can fit is to have it rotated 90 degrees vs. the existing fan (i.e. so it vents to the right (which is towards the roof vent)). This would require removing the small piece of wood (circled) to create sufficient space.
This is all new to me as a first-time homeowner so I’d love to get your thoughts on whether this is a wise approach, and if so, how would you suggest removing the wood / going about it. I’d greatly appreciate any advice on this and also any other suggestions for how to make it work!
