The two switches are Fused Spurs, used to "control" things such as a tumble drier / washing machine / lights where a 5 Amp fuse is advised, in short it is a way of controlling the amperage from the standard house 13 Amp down to a safe amperage for [say] a light, but a W/Machine will need a 15 Amp fuse, just to confuse?? but a TV may only need a 2 Amp fuse??
Can I suggest, that you change the two fuses in the two fused spurs, you can do this by opening the rectangular flaps on the spurs, the fuses are then accessible, suggest you change on a like for like basis.
Based on the right hand spur having a conduit rising vertically, there is a good chance??? that that spur controls the external lights??
Would like to know how you get on?? after a fuse change??
Ken.
