- Joined
- Jun 28, 2019
- Messages
- 6
- Reaction score
- 1
- Country
Hi All,
Can someone help advise me on my plan to build a fitted wardrobe in a bedroom. I intend to put to the left of a chimney breast (see picture), and I have a few questions.
Question 1: I intend to buy 2 spacepro shaker doors from b&q and an end piece. (https://www.diy.com/departments/sha...wardrobe-door-h-2220-mm-w-762mm/964874_BQ.prd) The space they are going to fit in is 1430mm wide. Both of these doors come to 1524mm which will leave an overlap of 90mm. Would that look wierd? If that is not the done thing, i have 2 alternate ways i figure i could approach it.
A) I could continue the track the extra 90mm past the chimney breast so the doors do not overlap. (the wardrobe will be proud from the front face of the chimney breast by about 300mm anyway, so i dont think you will tell it coninues past the start of the breast until you open it.)
B) There is a narrower door i could go for instead which is 610mm. They would come to 1220mm total, so i would need to fill in 105mm empty space at each side with Contiboard or something.
Question 2: Regardless which size door i pick, they are all 2220mm tall, and the floor to ceiling height of the room is 2530mm. So i am going to have to suspend the top track from the ceiling. I have found these: https://www.screwfix.com/p/spacepro-opening-height-reducer/7141r which i could use, or i could build some sort of timber frame if that is better? I guess i would have to use contiboard to fill in the gap, unless you guys know of something better to use?
Sidenote: One other thing i could do is run the wardrobe accross the entire back wall if you think that would be better, though i dont have the length measurements for that to hand as i'm writing this at work. I initially opted against this as the space between the doors and the front of the chimney breast would be about 100mm which from a storage perspective isnt going to be useful for much except storing trinkets and what not.
I downloaded the fitting instructions from The screwfix website, accessible from the following link if that helps:
