I'm doing some reglazing at the moment and having removed then replaced an opening window I thought I'd use solid brass screws to replace the rusty steel screws which I should have known better but why have it easy when I can really mess a job up; almost driven home the screw head broke away.
I needed to remove the broken screw so rather than mess the job up even more I made the drilling guide from a bit of steel seen above. The hinge was used to accurately align the screw holes; two holes were countersunk to accept the original screws the third hole was drilled at 5mm dia. Now I could screw this guide into position and very gently and carefully drill out the broken screw; a lot of care is needed otherwise a broken drill bit could join the broken screw. Using a sharp utilty knife I then made a dowel slightly larger diameter than the hole and with a spot of wood glue drove the dowel into the hole full depth; a pilot hole was then drilled and when the new steel screw was tightened I took care not to over tighten because it was now in end grain. Worked a treat . the metal drilling guide needs to be a decent thickness.
Just a quick tip because broken screws are so common and can be a real pain to remove.
Kind regards, ColinW.
