Am I correct ? the skirting has been pushed back into the wall near the floor?? not easy to see from the image posted??
if so? there is a chance that the new Laminate floor has insufficient edge space between the Laminate and the skirting.
When fitting Laminate flooring it is vital that there is a gap left between the laminate and the skirting, if the laminate touches the skirting then expansion of the laminate can / will either deform the skirting or cause the laminate to buckle.
Ken.
