Bow window / Curved Bay window Storage
Hi all
I'm starting a new project to create a built in storage unit to a bow window. I've had a look at tutorials online but can't find any relating to the curved wall.
My questions:
1. How you would go about building the frame to the wall. Usually you would have 3 pieces of timber attached to the wall and then build the rest of the frame from there. But with the curved wall i'm not sure that would work.
2. I think the wall is brick with plaster on top, so what would be the best screw/screw type and wall plugs to use for a sturdy fix as kids will climbing on it (will use 2x4 timber from what i have read online so the screw will need to be long enough to pass through the wood and into the wall).
Once i've figured out how to attach to the wall I'm sure I'll figure the rest out but would really appreciate any advice.
Photo below for reference
thanks
