Hi, super newbie here. I have some heavy floating shelves to hang on a wall which is essentially insulated plasterboard, a cavity and then standard brick.
The shelves come with fittings for a solid wall which is no good.
If I fit the solid wall bracket to the masonry (through the plasterboard) by reducing the length of the rod in the shelf, will this be a reasonable work around?
Or am I cutting too many corners with this approach? Any advice will be appreciated!
