Baxi Solo 2pf No hot water - rads ok
Hi.....our Baxi Solo 2pf heats the radiators fine but does not heat the water in the tank in hotpress...we use an immersion for hot water.
Any hints/tips appreciated !!
Thks...Gerico
With so little information provided it is almost impossible to give you an answer
Quote = does not heat the water in the tank in "hotpress" not sure what this means
Is the boiler even piped up to the cylinder ? :) if so the problem could be any one of these =
Blocked pipework around the cylinder area or coil in cylinder. (not unusual on the domestic return if cold feed is branched in here)
Is there an air vent on the top pipe going into the SIDE of the cylinder ? try venting it.
Balancing valve balanced down to much (if one is fitted)
3 port valve or hot water zone valve faulty (is it powering open)
Cylinder thermostat faulty
programmer faulty.
Hi....Thanks for reply & apologies for lack of detail !!
The water in the cylinder used to get hot but we just left it on long finger !! So, the boiler is piped up to cylinder...there doesn't seem to be any air vent on pipes around cylinder though , so no way of venting ... & no sign of a thermostat on the piping around cylinder either (unless its somewhere else ? ) !!
Balancing valve...I don't think there is one fitted.
I was looking to eliminate the most obvious possible problems before calling a heating guy !
Thks.
rapid
