I have just finished removing as much insulation as I can reach in our very low pitched roofed attic.
With 12 inch planks {supports?} running the length of the attic on either side I'm unable to access the edges to put in baffles for venting.
I plan on blowing insulation in but don't want to cover up the soffit vents.
Has anybody retrofitted baffles through the fascia?
If so, how? I'm new to this roofing game.
I realize I'll need to remove gutters to do this and will since much of the wood covering the fascia is rotted out and needs replacing.
Thank you to anyone with any ideas.
