- Joined
- Jan 15, 2011
- Messages
- 3
- Reaction score
- 0
I know that this topic has been raised before in various ways but having read the previous ones they are not the same as my situation and I have been unable to glean what is required although have attempted variations.
This model is the Manley model, but that is not relevant as it still has the same useless wiring diagram.
The fixture's wiring connection has a 4 wire block with a 5th noted as Loop, noted as below
Supply x-x Fan Motor
1) Switched Live x-x Brown (L)
2) Black or Blue (Neutral) x-x Blue (N)
3) Switched Live x-x Red (Light)
4) Green/Yellow (Earth) x-x Green/Yellow
5) Loop x-x Loop
Obviously the Fan Motor side is straight forward as the fitting matches the notes. Also Earth is an no-brainer. It's the supply side that is giving me trouble.
In removing the old standard rose, I made careful note of connections. I have 3 feeds for each of the 3 Live/Neutral/Earth (Red/Black/GY)
Ignoring the straight forward Earth, all of the red wires were in the same block so I presume are the "Loop". I, therefore, kept these in a seperate 5th connector as the loop.
The Brown/Live pendant feed had a single black connection (let's call it Black A), and the Blue/Neutral Feed had the other two black connectors( let's call them Black B & C). There are three other lights on the same circuit.
I connected Black A to connection 3 (Red Light)
I initially connected Black B to connection 2N and Black C to 1L. This way around the neither the fan or the light worked and 2 out of the 3 other lights on the circuit didn't work either.
Connecting both Black B&C to connection 2N means that the light works but the fan doesn't. Plus all lights on the circuit work. This is how it has been left, so I have a fan/light fitting with no working fan.
Variations I have tried which also didn't work include, connecting the red loop leads to connection 1L and (not at the same time) connecting Black A to connection 1L.
I am now at a loss.
Please Help
5) Loop x-x Loop
I am now at a loss.
Please Help
