Found this old guy at a garage sale years ago, I suspect it dates back maybe 80 years or so. Still worked like a charm, but as you can see, it was very dirty and the wiring was obviously very old. I am NOT an electrician, as will probably be obvious in a minute or two, but when I took it apart, cleaned it and re-wired it, I swear I wired it as the original, with the exception of adding a ground. Only the top ceramic element works...in the back view, it is the one furthest from the inlet. Obviously, I have something bass ackward, and any help will certainly be appreciated. Thanks in advance.
