This is a 2 stage furnace. It will not go to 2nd stage. I have watched/waited the 10 min after thermostat calls for heat, it starts to go to use 2nd stage then just goes back to 1st stage and does keep running. It then shows a flash code from the controller board = 7 -> Gas valve circuit error.
I did replace the flame censor, it made no difference. What's next? Replace the gas valve?
