Air tub/faceless GFCI
i want to install an air tub that requires a 15 amp breaker with 12 AWG. i want to install a faceless GFCI but im not sure where is a good place to locate it. i was thinking of putting it next to the gfci outlet over the sink so that it looks clean. any suggestions?? i know its supposed to be at least 5 feet away but not more then 10, my bath is small so thats no concern.
i wanted to know if the tub instructions are correct to when it comes to the wiring. is a 15 amp breaker with at least12 guage wire enough, with a regular outlet under the tub and a faceless GFCI in the bathroom. suggestions?
air turbine:
moter-0.8HP, 120V, 600W, 5AMPS
air heater: 700w, 5.8AMPS
its all 1 unit with 1 plug.
im in connecticut usa.
thank you!!
rapid
