Based in California, I am adding an outlet, extending from an existing outlet. I have completed and received the permit, and will do all the work myself (lots of industrial experience in electrical from my past )
I obviously need to rough in the romex from the current outlet to the new outlet, observing all code for running the romex, boxes, etc
The outlet I am running the extension *from* is existing. I would normally shut off the power to this for the duration of the work. However, this outlet is on the same circuit as my thermostat, so powering this off means no HVAC (its 100degrees tomorrow here).
I was planning on powering off, running the new romex into the box, leaving the currently connected and insulated (wirenuts) wiring out of the box and visible, but re-power them so that HVAC is working.
Any idea if this will be ok with the city?
