I've seen a few comments on this topic already, but none reflect my particular situation, so I hope you don't mind if I put forward my case.
I am trying to put a new light fitting up (big heavy brass thing). There are 9 wires hanging out of the ceiling - 3 red, 3 black, 3 green/yellow.
My light fitting has 1 blue, 1 brown, 1 green/yellow.
I tried attaching the blacks to the blue, the reds to the brown and the green/yellows together.
When switching on the lights at the fuse box, they came on despite the light switch being off. One of the bulbs immediately smoked and fused. When I then turned the light switch to 'on', everything fused, and, even with the light fitting removed, I now can't get any of the lights to turn on again.
I hope I haven't done anything fatally wrong...
Please could someone help on 1) whether I've done permanent damage 2) how I should be attaching this light fitting. (note, a 'rose' doesn't fit between the fitting and the ceiling).
Thank you for your help
Kredman
Kredman
